[QGIS-trac] Re: [Quantum GIS] #3437: Add natgrid to IGNF's RGF93
	projections
    Quantum GIS
    qgis at qgis.org
    Thu Mar  3 06:37:27 EST 2011
#3437: Add natgrid to IGNF's RGF93 projections
        Reporter:  jrm                               |         Owner:  jef
            Type:  patch                             |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Projection Support                |       Version:  Trunk
      Resolution:  invalid                           |      Keywords:  IGNF
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment(by jc):
 This french thread show there is a projection problem, but the solution
 can't be this patch, else WGS84 data won't mismatch. I talk WGS84 because
 it's the proj4 reference.
 I read your file a_lire.txt in your package test_qgis_l93.zip and I see
 only a +wktext addition (also in your forum comment), not any +nadgrids
 add. Is there a mistake in your a_lire.txt file ?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3437#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
