[QGIS-trac] Re: [Quantum GIS] #2626: better handling to change snapping options
Quantum GIS qgis at qgis.org
Fri Mar 4 06:09:59 EST 2011
        Reporter:  gespiel           |         Owner:  nobody
            Type:  enhancement       |        Status:  reopened
        Priority:  minor: annoyance  |     Milestone:  Version 1.6.0
       Component:  Digitising        |       Version:  Trunk
      Resolution:                    |      Keywords:
Platform_version:  xp sp3            |      Platform:  Windows
        Must_fix:  No                |   Status_info:  0
Changes (by gespiel):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 thanks for your work.
 I have installed trunk r15328 (trunk nr. 81).
 My suggestion is to optimize catching function.
 In the attached examples, i want to digitize a new polygon in the layer
 "testpolygoncadfunctions".
 I catch from the vertexes from the layer "Flurstuecke"
 The problem is, that normaly, I do not see the vertexes of the layer
 "Flurstuecke" (see attached picture 1). The result of the digitzed polygon
 is not precise.
 I only see the vertexes of the layer "Flurstuecke", when I set the layer
 "Flurstuecke" in the edit mode. That is not good, because I dont want edit
 the layer "Flurstuecke". Therfore, i proposed, to add in the window
 "catching options" a chekbox to see the vertexes of the layer, you catch
 from, in my example, I want to see the vertexes of the layer
 "Flurstuecke".
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2626#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
