[QGIS-trac] Re: [Quantum GIS] #3418: Layer Color Selector Crashes
Quantum GIS qgis at qgis.org
Sat Mar 5 13:53:21 EST 2011
        Reporter:  drawman                                    |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.7.0
       Component:  Symbology                                  |       Version:  1.6.0
      Resolution:  invalid                                    |      Keywords:
Platform_version:  0SX 10.5.8                                 |      Platform:  OS X
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by jctull):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Your attached file cannot be used for testing. You need all the parts that
 go along with the shapefile (.dbf, etc.). Try zipping those into an
 archive and attach. This may be a problem with your file because I do not
 have this issue on my system, although I am using trunk. I still have the
 problem noted in #2127, but I believe this is a problem with qt, not QGIS.
 I'm setting this to invalid until we can verify that the problem occurs
 for others.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3418#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
