[QGIS-trac] Re: [Quantum GIS] #2336: loading a project from the
command line results in broken rendering
Quantum GIS
qgis at qgis.org
Mon Mar 7 11:48:08 EST 2011
#2336: loading a project from the command line results in broken rendering
Reporter: ricardogsilva | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance | Milestone: Version 1.7.0
Component: Project Loading / Saving | Version: Trunk
Keywords: | Platform_version: Ubuntu 10.04
Platform: Debian | Must_fix: No
Status_info: 0 |
Comment(by aghisla):
I can notice a slight change in scale when I follow these steps:
1- Open QGIS maximised, load a layer, save the project as it is[[BR]]
2- Reopen the project, unmaximise the window, when asked if to save the
project, say no[[BR]]
3- Reopen the project, so that QGIS will remember last window size
(unmaximised) while the project was saved full with the maximised window.
It is a small changement, not as big as the attached screenshot show, even
if i change window size and proportions a lot. If you can share the point
data and the project that causes the problem, I'll try to reproduce the
bug.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2336#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
