[QGIS-trac] [Quantum GIS] #3570: Delimited text fix for data changes
Quantum GIS qgis at qgis.org
Tue Mar 8 14:44:00 EST 2011
   Reporter:  ccrook                                      |              Owner:  nobody
       Type:  patch                                       |             Status:  new
   Priority:  critical: causes crash or data corruption   |          Milestone:  Version 1.7.0
  Component:  Build/Install                               |            Version:  Trunk
   Keywords:  delimited text provider, bad layer handler  |   Platform_version:
   Platform:  All                                         |           Must_fix:  Yes
Status_info:  0                                           |
 The datasource format in the delimited text provider was changed in
 revsion 15177 to use the QUrl.toLocalFile() format.  This change wasn't
 also applied in qgshandlebadlayers.cpp, and the qgsmaplayer.cpp relative
 to absolute file format conversion.   This patch applies these fixes.
 Note that this change to the datasource could affect any plugins which
 create delimited text data sources.
 It will also break projects with delimited text layers moving from version
 1.6 to 1.7 - users need to be aware of this!
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3570>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
