[QGIS-trac] Re: [Quantum GIS] #121: join external tables to
geometries
Quantum GIS
qgis at qgis.org
Thu Mar 10 10:28:18 EST 2011
#121: join external tables to geometries
Reporter: mlennert@… | Owner:
Type: enhancement | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by mlennert):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:25 mhugent]:
> Thank you for the good example data. The issue should be fixed with
r15389.
Yes, great !
However, I've found another issue:
1) Load a shape and a dbf file (e.g. the attached demo data)
2) Join the two
3) Save the project
4) Close QGIS
5) Open QGIS
6) Load project
=> The join is still active. Perfect !
But:
2) Join the two
3) Map an indicator using Graduated symbol (e.g. Median age)
4) Save the project
5) Close QGIS
6) Open QGIS
7) Load project
=> "Handle bad layers" window opens, but I just can't get the shape file
to load anymore
This only happens when I use the old symbology, not the new.
Reopening the bug as I believe that this is an integrate part of the
feature that needs to work.
Feel free to close again if you don't believe so.
Moritz
Ticket URL: <http://trac.osgeo.org/qgis/ticket/121#comment:26>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
