[QGIS-trac] Re: [Quantum GIS] #3291: when digitizing,
show vertexes of the layer, you catch from
Quantum GIS
qgis at qgis.org
Thu Mar 10 16:36:26 EST 2011
#3291: when digitizing, show vertexes of the layer, you catch from
Reporter: gespiel | Owner: nobody
Type: enhancement | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Digitising | Version: Trunk
Resolution: fixed | Keywords:
Platform_version: xp sp3 | Platform: Windows
Must_fix: No | Status_info: 0
Changes (by gespiel):
* status: new => closed
* resolution: => fixed
Comment:
Copy content fom ticket 2626
thanks for your work. I have installed trunk r15328 (trunk nr. 81). My
suggestion is to optimize catching function. In the attached examples, i
want to digitize a new polygon in the layer "testpolygoncadfunctions". I
catch from the vertexes from the layer "Flurstuecke" The problem is, that
normaly, I do not see the vertexes of the layer "Flurstuecke" (see
attached picture 1). The result of the digitzed polygon is not precise.
I only see the vertexes of the layer "Flurstuecke", when I set the layer
"Flurstuecke" in the edit mode. That is not good, because I dont want edit
the layer "Flurstuecke". Therfore, i proposed, to add in the window
"catching options" a chekbox to see the vertexes of the layer, you catch
from, in my example, I want to see the vertexes of the layer
"Flurstuecke".
Changed 6 days ago by gespiel
■attachment see_vertexes_layer_catching_from_1.jpg added
■attachment see_vertexes_layer_catching_from_2.jpg added
Changed 6 days ago by pcav ¶
You can see them if you set the other alyer as editable. If this solves
for you, please close this ticket.
From gespiel
---> It is not the best solution to set the layer you catch from in edit
mode, but i accept it and close the ticket.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3291#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
