[QGIS-trac] Re: [Quantum GIS] #3586: use authid instead of proj.4
	strings
    Quantum GIS
    qgis at qgis.org
    Thu Mar 10 18:34:35 EST 2011
#3586: use authid instead of proj.4 strings
        Reporter:  jef                               |         Owner:  jef
            Type:  patch                             |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Projection Support                |       Version:
      Resolution:  fixed                             |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:5 borysiasty]:
 > But what with project files? Both authid and proj string are saved.
 > JEF, could you please confirm that authid is higher prriority and
 hopefully close the ticket again?
 looks like it.  order is authid, epsg, proj.4 and as last resort a CRS
 initialized with all the values from the node.   Otherwise we should have
 hit the 'Hartebeesthoek94' problem earlier...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3586#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
