[QGIS-trac] [Quantum GIS] #3597: qgis-dev crash when load a project
that is created before rel nr. 85 and it contains raster layer
Quantum GIS
qgis at qgis.org
Fri Mar 11 15:23:53 EST 2011
#3597: qgis-dev crash when load a project that is created before rel nr. 85 and it
Reporter: gespiel | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: GUI | Version: Trunk
Keywords: | Platform_version: xp sp3
Platform: Windows | Must_fix: Yes
Status_info: 0 |
since i updated qgis-dev from rel 83 to 85, Qgis-dev crash when i try to
load an existing project and the project contains raster leayer. If the
project contains only vector layer, the project is load normally.
In the windows event browser, I find the following entry:
Ereignistyp: Fehler
Ereignisquelle: Application Error
Ereigniskategorie: Keine
Ereigniskennung: 1000
Datum: 11.03.2011
Zeit: 21:08:22
Benutzer: Nicht zutreffend
Computer: PCGER
Beschreibung:
Fehlgeschlagene Anwendung qgis.exe, Version 0.0.0.0, fehlgeschlagenes
Modul qtcore4.dll, Version 4.7.1.0, Fehleradresse 0x00056df0.
Weitere Informationen über die Hilfe- und Supportdienste erhalten Sie
unter http://go.microsoft.com/fwlink/events.asp.
Daten:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 71 67 69 ure qgi
0018: 73 2e 65 78 65 20 30 2e s.exe 0.
0020: 30 2e 30 2e 30 20 69 6e 0.0.0 in
0028: 20 71 74 63 6f 72 65 34 qtcore4
0030: 2e 64 6c 6c 20 34 2e 37 .dll 4.7
0038: 2e 31 2e 30 20 61 74 20 .1.0 at
0040: 6f 66 66 73 65 74 20 30 offset 0
0048: 30 30 35 36 64 66 30 0d 0056df0.
0050: 0a .
Thanks for a solution
Gerhard
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3597>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
