[QGIS-trac] Re: [Quantum GIS] #3583: patch to use the same pal instance for labeling-ng and for diagrams
Quantum GIS qgis at qgis.org
Mon Mar 14 11:24:45 EDT 2011
   Reporter:  mhugent                                    |              Owner:  nobody
       Type:  patch                                      |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Build/Install                              |            Version:
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
Comment(by timlinux):
 Hi Marco
 I wanted to comment that the 'Fixed Size' box was checked for me by
 default, but the size defaults to 0. In the beginning of testing I couldnt
 figure out why no diagrams were rendering and I am sure 'normal' users
 will be caught out by this too.
 Lastly I had issues trying to make it work together with labels for the
 same layer. When I enabled labelling, no diagrams showed (no matter what
 scale). Even after turning off labels, you have to go back to layer
 properties and press apply before the diagrams reappear.
 Lastly it seems priority for the diagrams is set to 0 by default which I
 thought might be the cause of the above, but changing priority had no
 effect.
 I'm going to attach the sample dataset I used.
 Regards
 Tim
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3583#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
