[QGIS-trac] [Quantum GIS] #3613: map units not honored for line offset
Quantum GIS qgis at qgis.org
Mon Mar 14 12:53:07 EDT 2011
   Reporter:  best                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Symbology                         |            Version:  Trunk
   Keywords:  line offset map units             |   Platform_version:  XP
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 to reproduce do the following
 1) add a polygon layer
 2) use new symbology
 3) add a "Outline: Simple line" width 5, color green
 4) add a "Outline: Simple line" width 1, offset -6, color black
 this should result in a thick green line with a black line at the outer
 edge in any scale
 5) change units to "Map unit"
 this results in the two lines getting thicker when zooming in but the
 distance between them stays constant in screen units!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3613>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
