[QGIS-trac] [Quantum GIS] #3621: Projecting not working in MacOS
Quantum GIS qgis at qgis.org
Tue Mar 15 10:54:01 EDT 2011
   Reporter:  Geir                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:  1.6.0
   Keywords:                                    |   Platform_version:  10.6.6
   Platform:  OS X                              |           Must_fix:  No
Status_info:  0                                 |
 I just installed the separate framework version of QGIS 1.6 Copiapo for
 Mac OS (I have used the standalone 1.5 until recently). Wanted to add a
 GPX file to a project which otherwise have UTM WGS84 33N projected layers.
 I used the "save as shape file" option and chose the UTM WGS84 33N
 projection of the new file (as I have done hundreds of times before). In
 the resulting shape file the projection was set to UTM WGS84 33N, however
 the coordinates are not projected and the use of the function "Add
 geometry columns" showed that the coordinates was the same lat. long
 coordinates as in the GPX file. Tried to do the same thing again, but
 using original CRS when converting to shape file. Then I tried to project
 that resulting shape file using the "Export to new projection"
 function....same result. Adding the lat long shape file to the project
 with "on the fly projection" activated doesn´t help either. Seems like the
 projection simply are not working
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3621>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
