[QGIS-trac] Re: [Quantum GIS] #3632: incorrect reprojection on
windows (7), fine on linux
Quantum GIS
qgis at qgis.org
Thu Mar 17 03:35:24 EDT 2011
#3632: incorrect reprojection on windows (7), fine on linux
Reporter: nirvn | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: Projection Support | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
Description changed by jef:
Old description:
> There's an on the fly reprojection issue going on with QGIS on windows
> platform (working fine under linux, untested on mac).
> On the windows version of QGIS, a WGS84 datum layer and its Indian 1960
> 48N datum equivalent fails to project on top of each other, ending up in
> a +450 meter (!) difference in location. (see screenshot attached)
> I've been noticing this for quite some time but didn't find a good way to
> explain the issue until now.
> Steps to reveal issue:
> 1/ Create a new program, set the CRS to UTM Indian 1960 48N and activate
> on the fly reprojection.
> 2/ Load the raster @ http://licadho-cambodia.org/qgis/ASTGTM_N11E103.zip
> (it's a simple aster gdem geotiff) into the project
> 3/ Using the gdal's wrap tool, transform the astgm_n11e103_dem.tiff's
> WGS84 datum to Indian 1960 48N datum
> 4/ Load the generated raster
> 5/ Apply the this colormap (http://licadho-cambodia.org/qgis/bugramp.txt)
> to both rasters to make it easier to observe the issue
> Et voila.
> Loading the two rasters into the linux version of QGIS will render just
> fine.
New description:
48N datum equivalent fails to project on top of each other, ending up in a
1. Create a new program, set the CRS to UTM Indian 1960 48N and activate
1. Load the raster @ http://licadho-cambodia.org/qgis/ASTGTM_N11E103.zip
1. Using the gdal's wrap tool, transform the astgm_n11e103_dem.tiff's
1. Load the generated raster
1. Apply the this colormap (http://licadho-cambodia.org/qgis/bugramp.txt)
Et voila.
fine.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3632#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
