[QGIS-trac] Re: [Quantum GIS] #3641: Bug in ShapeFile to postgis import Tool
Quantum GIS qgis at qgis.org
Sat Mar 19 09:12:50 EDT 2011
   Reporter:  mickael1                  |              Owner:
       Type:  bug                       |             Status:  new
   Priority:  minor: annoyance          |          Milestone:  Version 1.7.0
  Component:  Vectors                   |            Version:  Trunk
   Keywords:  shapefile postigs import  |   Platform_version:  windows seven
   Platform:  Windows                   |           Must_fix:  No
Status_info:  0                         |
Changes (by jef):
 * cc: code, revision, 15530 (removed)
Old description:
> Once I've created a shapefile with dxf2shp module, I tried to use the
> module : shapefile to postis, but i got :
> The database gave an error while executing this SQL:
> SELECT AddGeometryColumn('public','test1','the_geom',-1,'NULL',2)
> The error was:
> ERREUR:  Invalid type name - valid ones are:
>         POINT, MULTIPOINT,
>         LINESTRING, MULTILINESTRING,
>         POLYGON, MULTIPOLYGON,
>         CIRCULARSTRING, COMPOUNDCURVE, MULTICURVE,
>         CURVEPOLYGON, MULTISURFACE,
>         GEOMETRY, GEOMETRYCOLLECTION,
>         POINTM, MULTIPOINTM,
>         LINESTRINGM, MULTILINESTRINGM,
>         POLYGONM, MULTIPOLYGONM,
>         CIRCULARSTRINGM, COMPOUNDCURVEM, MULTICURVEM
>         CURVEPOLYGONM, MULTISURFACEM,
>         or GEOMETRYCOLLECTIONM
> CONTEXT:  SQL statement "SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6)"
> fonction PL/pgsql « addgeometrycolumn », ligne 4 à instruction SQL
New description:
 The error was:
         POINT, MULTIPOINT,
 Using r15530.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3641#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
