[QGIS-trac] Re: [Quantum GIS] #3651: Possibility to set rotation constraint for pal label candidate generation (was: label rotation not working as expected)
Quantum GIS qgis at qgis.org
Thu Mar 24 17:04:29 EDT 2011
   Reporter:  jctull                            |              Owner:  mhugent
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Vectors                           |            Version:  Trunk
   Keywords:  label rotation                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Changes (by mhugent):
  * platform:  OS X => All
  * type:  bug => enhancement
Comment:
 The new labeling has two distinct modes:
 1. fully automatic mode: pal library determines possible positions and
 rotations (depending on placement options set)
 2. fully data defined mode: one candidate position with fixed position and
 optionally rotation is forced
 What you describe would be a way to go with 1. but to specify a rotation.
 This is not totally impossible, but requires enhancements in the candidate
 generation code of the pal library. I'm therefore changing the type of
 this ticket.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3651#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
