[QGIS-trac] Re: [Quantum GIS] #3187: transform ring into new polygon
Quantum GIS qgis at qgis.org
Tue Mar 29 13:40:38 EDT 2011
        Reporter:  mlennert                     |         Owner:  jef
            Type:  enhancement                  |        Status:  closed
        Priority:  minor: annoyance             |     Milestone:  Version 1.7.0
       Component:  Python plugins and bindings  |       Version:
      Resolution:  fixed                        |      Keywords:
Platform_version:                               |      Platform:  All
        Must_fix:  No                           |   Status_info:  0
Comment(by mlennert):
 Replying to [comment:8 lutra]:
 > Replying to [comment:7 mlennert]:
 > > Replying to [comment:6 p0cisk]:
 > > > Hi
 > > > Try to use plugin 'Ringer' from QGIS Contributed Repository
 (experimental).
 > > > Select polygons to transform there rings to polygons. If you didn't
 select any polygons, all rings will be converted.
 > > I've installed and activated it, but it stays greyed out and non-
 active in the Extensions menu be it with polgons selected or without.
 > > Moritz
 > toogle editing...
 dooh. ;-)
 Works great, thanks !
 Might be nice to be able to pop up the attribute form once a ring becomes
 a polygon, but don't know how this could be done when filling multiple
 rings at once...So, this is already a very nice solution as is.
 Moritz
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3187#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
