[QGIS-trac] Re: [Quantum GIS] #3799: Cannot add new OGR layer types
Quantum GIS
qgis at qgis.org
Thu May 5 02:19:56 EDT 2011
Reporter: mattwigway | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone:
Component: Data Provider | Version:
Keywords: ogr couchdb | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Changes (by jef):
* platform: Fedora => All
* version: 1.6.0 =>
* type: bug => enhancement
Old description:
> As of OGR 1.9, CouchDB Spatial is now supported, but QGIS does not allow
> you to add the layer. It would be good if either
> a) CouchDB could be added to the "add vector layer" database tab; or
> b) have a place where you can specify an OGR URL directly.
> b) is probably better, because then other data sources can be used before
> they've been officially added to QGIS.
New description:
As of OGR 1.9, [http://gdal.org/ogr/drv_couchdb.html CouchDB Spatial] is
now supported, but QGIS does not allow you to add the layer. It would be
good if either
a. CouchDB could be added to the "add vector layer" database tab; or
a. have a place where you can specify an OGR URL directly.
b. is probably better, because then other data sources can be used before
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3799#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
