[QGIS-trac] Re: [Quantum GIS] #3648: Qgis 1.6/trunk, osgeo4w/standalone hangs/crashes when adding GRASS vectors in a QGIS project (was: Qgis 1.6/trunk, osgeo4w/standalone crashes when importing vectors in a GRASS mapset or when adding them to the project)
Quantum GIS qgis at qgis.org
Thu May 5 18:13:59 EDT 2011
in a QGIS project
   Reporter:  lutra                                      |              Owner:  rblazek
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  GRASS                                      |            Version:  1.6.0
   Keywords:                                             |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
Comment(by lutra):
 Hi all,
 I finally made further tests, using qgis/osgeo4w (both 1.6 and trunk) and
 trunk/standalone created with creatensis.pl
 Used a *clean* Windows Seven environment
 Results
 A) qgis 1.6 osgeo4w and 1.7 standalone:
 adding a GRASS vector to the qgis canvas (via the GRASS browser or using
 the "view output" button, for example after having imported a vector)
 *usually* works, but at some point it will happen that adding a new vector
 qgis will hang and you will need to take it down.
 After many hours of testing I realized that it is absolutely random: it
 doesn't depend on the vector, or the kind of geometry or the
 complexity/size or its projection. It is simply random. It can happen when
 adding the first vector in a project or after 20 tries. Sooner or later
 qgis will choke.
 B) qgis trunk/osgeo4w:
 qgis immediately crashes (not hangs as before) when adding a GRASS vector
 in a qgis project.
 Forget about the vector I attched to this ticket, if you want to replicate
 the issue just use the QGIS sample dataset,
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3648#comment:18>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
