[QGIS-trac] [Quantum GIS] #3806: Make click anywhere in symbol
select/identify
the object (i.e. when symbol is bigger than the actual object)
Quantum GIS
qgis at qgis.org
Sun May 8 06:08:16 EDT 2011
#3806: Make click anywhere in symbol select/identify the object (i.e. when symbol
Reporter: Alister | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 2.0.0
Component: GUI | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Currently if you use a large point symbol you still need to click right in
the center of the symbol when using the info or select single symbol
tools. This is confusing: I think it is intuitive for these tools to work
when you click anywhere inside the symbol.
Similarly, if you use a thick line for a polyline layer (or a polygon
border) you currently need to click right in the middle of the line (or
inside the polygon).
Also see #3805 regarding snapping
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3806>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
