[QGIS-trac] Re: [Quantum GIS] #3806: Make click anywhere in symbol
select/identify the object (i.e. when symbol is bigger than the
actual object)
Quantum GIS
qgis at qgis.org
Sun May 8 06:18:45 EDT 2011
#3806: Make click anywhere in symbol select/identify the object (i.e. when symbol
is bigger than the actual object)
Reporter: Alister | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 2.0.0
Component: GUI | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Comment(by Alister):
No, this is not quite the same as tolerance. It is about the symbol being
bigger than the actual object.
e.g. if I symbolise a point layer with 20mm circles then most users would
expect that if they click anywhere in the circle then it would select or
identify the object. But they actually need to click right in the centre
of the circle (or the tolerance distance from the centre).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3806#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
