[QGIS-trac] [Quantum GIS] #3820: Layer postgres dont recognize
unique key index
Quantum GIS
qgis at qgis.org
Wed May 11 13:13:05 EDT 2011
#3820: Layer postgres dont recognize unique key index
Reporter: aperi2007 | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version: 7
Platform: Windows | Must_fix: No
Status_info: 0 |
try-ing to load a view in qgis I'm having this
error:
The view 'gb.v_volumetria_in_aggetto' has no column suitable for use as a
unique key.
Quantum GIS requires that the view has a column that can be used as a
unique key. Such a column should be derived from a table column of type
int4 and be a primary key, have a unique constraint on it, or be a
PostgreSQL oid column. To improve performance the column should also be
indexed.
The view you selected has the following columns, none of which satisfy the
above conditions:
'altezzavolume' derives from 'gb.volumetria_in_aggetto.altezzavolume' and
is not suitable (type is varchar) and does not have a suitable constraint)
'codcategoriauso' derives from 'gb.volumetria_in_aggetto.codcategoriauso'
and is not suitable (type is varchar) and does not have a suitable
constraint)
'codvolagg' derives from 'gb.superficie_3d.codvolagg' and is not suitable
'codvolumetriainaggetto' derives from
'gb.volumetria_in_aggetto.codvolumetriainaggetto' and is not suitable
(type is varchar) and has a suitable constraint)
'documentation' derives from
'gb.zz_categoriausovolumetriaaggettotype.documentation' and is not
'geom' derives from 'gb.superficie_3d.geom' and is not suitable (type is
geometry) and does not have a suitable constraint)
'id' derives from 'gb.volumetria_in_aggetto.id' and is not suitable (type
is int4) and does not have a suitable constraint)
'quotaestrusione' derives from 'gb.volumetria_in_aggetto.quotaestrusione'
constraint)
'value' derives from 'gb.zz_categoriausovolumetriaaggettotype.value' and
is not suitable (type is varchar) and has a suitable constraint)
I think this is a bug because the id field derives from
'gg.volumetria_in_aggetto' is really suitable.
it is a serial (so is unique) and has a unique index created with this
sql:
CREATE UNIQUE INDEX IDX_VOLUMINAGG0 ON [schema].VOLUMETRIA_IN_AGGETTO(ID);
instead qgis refuse it reporting:
The view is create with this sql:
CREATE VIEW gb.v_volumetria_in_aggetto AS
SELECT
a.id as id,
a.codvolumetriainaggetto as codvolinag,
a.altezzavolume as altezvolum,
a.quotaestrusione as quotaestru,
c.documentation as codcatuso,
ST_Union(b.geom) as geom
FROM
(( gb.volumetria_in_aggetto a
LEFT OUTER JOIN [schema].superficie_3d b ON
(a.codvolumetriainaggetto = b.codvolagg) )
LEFT OUTER JOIN [schema].zz_categoriausovolumetriaaggettotype c ON
(a.codcategoriauso = c.value) )
GROUP BY
a.id,
a.codvolumetriainaggetto,
a.altezzavolume,
a.quotaestrusione,
c.documentation
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3820>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
