[QGIS-trac] [Quantum GIS] #3831: Add customizable Online Resource
for QGIS-mapserver to be configurable via properties-section in
projectfile
Quantum GIS
qgis at qgis.org
Wed May 18 07:31:32 EDT 2011
#3831: Add customizable Online Resource for QGIS-mapserver to be configurable via
properties-section in projectfile
Reporter: mlechner | Owner: mhugent
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 2.0.0
Component: mapserver | Version: Trunk
Keywords: Online Resource mapserver | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
When using qgis-mapserver with a map-parameter pointing to a qgis-
projectfile, the Online Resource in the GetCapabilities Doc is served
without this parameter. As a result clients using the informations in
GetCapabilities doc will not be able to create correct requests for GetMap
or GetFeatureInfo. qgis is one of those clients where this could run into
problems.
Solution: add fields in the project definitions to provide a custom URL
used for the GetCapa-doc. this makes it possible to add the correct URLs
including the map-parameter.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3831>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
