[QGIS-trac] Re: [Quantum GIS] #3810: Join attributes by location
crash
Quantum GIS
qgis at qgis.org
Fri May 20 10:16:42 EDT 2011
#3810: Join attributes by location crash
Reporter: bderstine | Owner: cfarmer
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: fTools | Version: Trunk
Keywords: | Platform_version: 7, 64-bit
Platform: Windows | Must_fix: No
Status_info: 1 |
Changes (by bderstine):
* priority: critical: causes crash or data corruption => major: does not
work as expected
* type: bug => enhancement
Comment:
More detail: I tried again today with 1.8.0-10.
Attribute Summary set to "Take attributes of fist located feature"
Output table: Keep all records (including non-matching target records)
Process started at 8:35am, progress bar jumped to 15% immediately and then
doesn't move, and I get the little "thinking" mouse pointer (likely due to
all the processing that's happening behind the scenes, though this is not
ideal UI design).
A spatial join in ArcGIS constantly displays a running count of #
processed, in chunks, so you know that it's still actually doing
something. Something like that would vastly improve the UI here.
At 9:14am, I get the pop-up window telling me that it "created output
shapefile: ..." So I guess I was wrong. I guess I'll change this to
"enhancement" and "major".
I feel strongly that either (a) the progress bar needs to be fixed so that
it actually does update to show progress, or (b) some other indicator of
progress should be added to inform the user that the process is still
working.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3810#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
