[QGIS-trac] [Quantum GIS] #3837: new symbology line decoration has
wrong orientation when final vertices are duplicated
Quantum GIS
qgis at qgis.org
Tue May 24 06:28:48 EDT 2011
#3837: new symbology line decoration has wrong orientation when final vertices are
duplicated
Reporter: strk | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Symbology | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
After a long time happyness due to closing ticket #3434 the wrong arrow
orientation bug is back.
This time the problem is due to lines having duplicated vertices toward
the end, so that the "last segment" is empty.
I hit this bug while testing handling of such cases by postgis topology so
it was intentional to have lines with endings collapsed.
Example:
LINESTRING(10 0, 0 0, 0 0)
I haven't checked this specific case but what I'm looking at right now is
an arrow pointing o the right, so I guess you'd see the same right-
pointing arrow for the case above (which is instead going to the left).
Note that the same right-arrow should appear for any line orientation:
vertical or diagonal...
Label orientation might be affected too, but didn't try to produce that
bug (I guess it'd take making it so that centroid of the line falls on a
collapsed segment)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3837>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
