[QGIS-trac] Re: [Quantum GIS] #3765: on trunk/windows ECW files
take a long time to open (qgis hangs)
Quantum GIS
qgis at qgis.org
Thu May 26 04:02:11 EDT 2011
#3765: on trunk/windows ECW files take a long time to open (qgis hangs)
Reporter: lutra | Owner: nobody
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Rasters | Version: Trunk
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment(by lutra):
when I opened the ticket I had the issue on both linux and windows, now I
cannot see it anymore on both OS. I also tested > 100mb ECW and it opens
fast as expected.
I suspect that this can be related to local installation situations. I had
a mix of gdal libraries in my linux pc due to different repositories
installed and I was seeing many problems with rasters. After a cleaning
and reinstalling from source it works all ok.
I reinstalled completely also QGIS from osgeo4w after having removed it
not using the same installer: i removed the shortcuts and the osgeo4w
installation directory and the cleaned everyhting with ccleaner and other
tools for the Windows registry. Upon reinstallation I'm not having anymore
problems.
Could you give it a try?
I have no problems with -for example- this 90mb ecw image
http://www.pfc.forestry.ca/eosd/resources/mosaic/2000/Canada_Mosaic_2000_250m_ecw.zip
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3765#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
