[QGIS-trac] Re: [Quantum GIS] #3126: Sliver holes remain after
dissolve
Quantum GIS
qgis at qgis.org
Fri May 27 14:36:43 EDT 2011
#3126: Sliver holes remain after dissolve
Reporter: gislab | Owner: jef
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version: Trunk
Resolution: invalid | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment(by strk):
GEOS only employs snaprounding IFF w/out it it could not properly node the
input, so it's a fallback rather than a feature. The approach is to keep
as much precision as possible during union operations.
Starting with GEOS-3.3.0 an entry point for snapping is available in the
C-Api.
Not sure it's needed as Qgis might be perfectly capable of doing the
snapping part itself.
I guess it might make sense to expose an option in the qgis gui to do some
snapping/renoding before running an union.
Mind you: this is not a bug, as the vertices of those slivers are most
likely _not_ exactly the same, altought they might look like identical
when converted from binary to decimal representation.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3126#comment:16>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
