[QGIS-trac] [Quantum GIS] #3853: Problems with some WMS services
(from toronto.ca/open)
Quantum GIS
qgis at qgis.org
Sat May 28 23:19:16 EDT 2011
#3853: Problems with some WMS services (from toronto.ca/open)
Reporter: mgleahy | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Build/Install | Version: 1.6.0
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
I've notice a problem when I try to load layers from the WMS services
listed at http://toronto.ca/open (follow the big "Get the Data" link, then
scroll to the bottom of the page). When I connect to these directly
within QGIS, I can see the list of layers, projection info, etc. But when
I try to add them to the map the layers just appear blank (and do not have
default extents that I can zoom to). You can try it yourself by adding a
WMS server in QGIS with the 'CONNECTION' url in the sample mapfile below,
then try adding one or more layers from it...the layers will appear in the
layer control in QGIS, but no data will appear in the map. Using the
sample mapfile below, I was able to use !MapServer as a local proxy for
the WMS service. By connecting QGIS to the wms_onlineresource metadata
parameter below, I am able to get the Ortho Imagery displayed from the
Toronto WMS service.
Based on this, !MapServer clearly doesn't have a problem requesting data
from the Toronto WMS service. QGIS in turn is able to use !MapServer.
However, although this can serve as a workaround, it isn't an ideal
solution. It appears that this is a problem with the ability of QGIS to
interoperate directly with the Toronto WMS service. I checked with the
users list first, and it was recommended that this be reported here.
/path/to/wms.map:
MAP
NAME "Toronto OrthoImagery (proxy)"
STATUS ON
SIZE 1024 1024
EXTENT 292998.8237 4824999.2385 336000.8237 4858001.2385
UNITS meters
PROJECTION
"init=epsg:2019"
END
IMAGECOLOR 255 255 255
TRANSPARENT ON
WEB
METADATA
'wms_title' 'Toronto OrthoImagery (proxy)'
'wms_onlineresource' 'http://localhost/cgi-
bin/mapserv?map=/path/to/wms.map&'
'wms_srs' 'EPSG:2019'
'ows_enable_request' '*'
END
END
LAYER
NAME "Ortho Imagery 50cm 2005"
STATUS ON
TYPE RASTER
CONNECTION
"http://map.toronto.ca:80/servlet/com.esri.wms.Esrimap/OrthoImagery?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:2019"
"wms_name" "Ortho Imagery 50cm 2005"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_title" "Ortho Imagery 50cm 2005"
END
PROJECTION
"init=epsg:2019"
END
END
END
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3853>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
