[QGIS-trac] [Quantum GIS] #3856: Print composer extents do not take into account CRS
Quantum GIS qgis at qgis.org
Tue May 31 03:56:26 EDT 2011
   Reporter:  Alister                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 Try this:
 - enable on-the-fly reprojection[[BR]]
 - add some layers[[BR]]
 - create a new composer layout and add a map to it.[[BR]]
 - make sure the extents of the composer layout are such that the layers
 are visible[[BR]]
 - change the project CRS[[BR]]
 The layers will no longer be visible in the composer layout because the
 composer layout extents are applied using the project CRS, and are not
 adjusted when the project CRS changes.
 Also see #3243 which is a similar issue for spatial bookmarks.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3856>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
