[QGIS-trac] [Quantum GIS] #3858: Not possible to define subset of
layer using field from joined table
Quantum GIS
qgis at qgis.org
Tue May 31 11:37:15 EDT 2011
#3858: Not possible to define subset of layer using field from joined table
Reporter: bnotter | Owner:
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Vectors | Version: Trunk
Keywords: table join, subset | Platform_version: Ubuntu 10.10
Platform: Linux | Must_fix: No
Status_info: 0 |
If a table is dynamically joined to a vector layer (as possible from QGIS
1.7), it is not possible to define a subset of the layer to be displayed
(as done in Layer Properties - General) based on a field of the joined
table.
If an SQL-Where-Clause is entered that refers to a field of the joined
table (in this case "MAINCROP", when clicking OK, an error message
appears:
"OGR[3] error 1: SQL: Failed to identify field:MAINCROP"
It would be good if this were made possible, as joining tables dynamically
makes less sense if for some purposes, the joined datasets still have to
be permanently saved into a new dataset.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3858>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
