[QGIS-trac] [Quantum GIS] #3859: segfault on exit after using GRASS
	layer
    Quantum GIS
    qgis at qgis.org
    Tue May 31 13:10:57 EDT 2011
#3859: segfault on exit after using GRASS layer
   Reporter:  strk                              |              Owner:
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  GRASS                             |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 Sorry for the weird Summary, but this is how I reproduce:
 1. start qgis
 1. add grass vector layer
 1. edit grass vector layer
 1. close the grass vector layer editing window (w/out touching anything
 else)
 1. close the main qgis window, w/out saving
 Here's a backtrace:
 Program received signal SIGSEGV, Segmentation fault.
 0x0000000000000001 in ?? ()
 (gdb) bt
 #0  0x0000000000000001 in ?? ()
 #1  0x00007ffff5fbd451 in QObject::disconnect(QObject const*, char const*,
 QObject const*, char const*) () from /usr/lib/libQtCore.so.4
 #2  0x000000000063e9ff in QObject::disconnect(QObject const*, char const*)
 #3  0x00007fffe1b0aef7 in QgsGrassEdit::closeEdit() ()
    from /usr/local/lib/qgis/plugins/libgrassplugin.so
 #4  0x00007fffe1aeaf95 in QgsGrassPlugin::~QgsGrassPlugin() ()
 #5  0x00007ffff5fb5a5c in QObjectPrivate::deleteChildren() ()
 #6  0x00007ffff53bd2d5 in QWidget::~QWidget() () from
 /usr/lib/libQtGui.so.4
 #7  0x000000000053ab6a in QgisApp::~QgisApp() ()
 #8  0x0000000000533d6f in main ()
 Sounds like a missing handling of the grass editor window close button.
 Note this is from the 1.7.0 branch, commit 2516c38 (there's no 1.7.0
 version in trac)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3859>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
