[Qgis-us-user] Problems installing QGIS on RHEL 6.9
Peter K Cattaneo
pkcattan at syr.edu
Mon Feb 4 09:42:17 PST 2019
Good afternoon,
I'm carefully trying to install QGIS on my Redhat workstation that is running a lot of other valuable software. I followed directions on the ELGIS repository and first installed elgis-release-6-6_0.noarch.rpm. It installed with no problem. I next went to install qgis, qgis-python and qgis-mapserver using yum. All three give a similar output problem like below. I'm a little uncomfortable changing the notify_only=0 option in the pluginconf.d file. Has anyone had a similar issue?
Thanks
Peter
[root at kifaru Desktop]# yum install qgis
Loaded plugins: product-id, refresh-packagekit, search-disabled-repos, security,
: subscription-manager
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package qgis.x86_64 0:1.8.0-16.el6 will be installed
--> Processing Dependency: gpsbabel for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libQtWebKit.so.4()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libgdal.so.1()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libgeos_c.so.1()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libgsl.so.0()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libgslcblas.so.0()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libpq.so.5()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libproj.so.0()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libqextserialport-1.2.so.1()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libqwt.so.5()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libqwtpolar.so.0()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libspatialindex.so.1()(64bit) for package: qgis-1.8.0-16.el6.x86_64
--> Processing Dependency: libspatialite.so.2()(64bit) for package: qgis-1.8.0-16.el6.x86_64
---> Package gdal-libs.x86_64 0:1.9.2-4.el6 will be installed
--> Processing Dependency: libmysqlclient.so.16(libmysqlclient_16)(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libxerces-c-3.0.so()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libnetcdf.so.6()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libmysqlclient.so.16()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libhdf5.so.6()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libgta.so.0()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libgeotiff.so.2()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libfreexl.so.1()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libdapserver.so.7()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libdapclient.so.3()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libdap.so.11()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libcfitsio.so.0()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libarmadillo.so.3()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
--> Processing Dependency: libCharLS.so.1()(64bit) for package: gdal-libs-1.9.2-4.el6.x86_64
---> Package geos.x86_64 0:3.3.8-2.el6 will be installed
---> Package gpsbabel.x86_64 0:1.5.0-3.el6 will be installed
--> Processing Dependency: libshp.so.1()(64bit) for package: gpsbabel-1.5.0-3.el6.x86_64
---> Package gsl.x86_64 0:1.13-1.el6 will be installed
---> Package libspatialite.x86_64 0:2.4.0-0.6_0.RC4.el6 will be installed
---> Package phantomjs.x86_64 0:1.6.0-4.el6.nux will be installed
--> Processing Dependency: qtwebkit for package: phantomjs-1.6.0-4.el6.nux.x86_64
---> Package postgresql-libs.x86_64 0:8.4.20-8.el6_9 will be installed
---> Package proj.x86_64 0:4.8.0-3.el6 will be installed
---> Package qextserialport.x86_64 0:1.2-0.6.beta2.el6 will be installed
---> Package qwtpolar.x86_64 0:0.1.0-5.el6 will be installed
--> Processing Dependency: libqwt.so.5()(64bit) for package: qwtpolar-0.1.0-5.el6.x86_64
---> Package spatialindex.x86_64 0:1.6.1-3.el6 will be installed
---> Package CharLS.x86_64 0:1.0-5.el6 will be installed
---> Package cfitsio.x86_64 0:3.240-3.el6 will be installed
---> Package freexl.x86_64 0:1.0.5-1.el6 will be installed
---> Package hdf5.x86_64 0:1.8.5.patch1-10.el6 will be installed
---> Package libdap.x86_64 0:3.11.0-1.el6 will be installed
---> Package libgeotiff.x86_64 0:1.4.0-1.el6 will be installed
---> Package libgta.x86_64 0:1.0.2-2.el6 will be installed
---> Package mysql-libs.x86_64 0:5.1.73-8.el6_8 will be installed
---> Package netcdf.x86_64 0:4.1.1-3.el6.5 will be installed
---> Package qtwebkit.x86_64 0:2.1.1-1.el6 will be installed
--> Processing Dependency: libQtBearer.so.1()(64bit) for package: qtwebkit-2.1.1-1.el6.x86_64
--> Processing Dependency: libQtLocation.so.1()(64bit) for package: qtwebkit-2.1.1-1.el6.x86_64
--> Processing Dependency: libQtMultimediaKit.so.1()(64bit) for package: qtwebkit-2.1.1-1.el6.x86_64
--> Processing Dependency: libQtSensors.so.1()(64bit) for package: qtwebkit-2.1.1-1.el6.x86_64
---> Package shapelib.x86_64 0:1.2.10-21.20060304cvs will be installed
---> Package xerces-c.x86_64 0:3.0.1-0.20.1.el6 will be installed
---> Package qt-mobility.x86_64 0:1.1.3-2.el6 will be installed
--> Finished Dependency Resolution
Error: Package: qwtpolar-0.1.0-5.el6.x86_64 (epel)
Requires: libqwt.so.5()(64bit)
Error: Package: qgis-1.8.0-16.el6.x86_64 (epel)
Error: Package: gdal-libs-1.9.2-4.el6.x86_64 (elgis)
Requires: libarmadillo.so.3()(64bit)
yum can be configured to try to resolve such errors by temporarily enabling
disabled repos and searching for missing dependencies.
To enable this functionality please set 'notify_only=0' in /etc/yum/pluginconf.d/search-disabled-repos.conf
You could try using --skip-broken to work around the problem
** Found 3 pre-existing rpmdb problem(s), 'yum check' output follows:
2:postfix-2.6.6-6.el6_7.1.x86_64 has missing requires of libmysqlclient.so.16()(64bit)
2:postfix-2.6.6-6.el6_7.1.x86_64 has missing requires of libmysqlclient.so.16(libmysqlclient_16)(64bit)
2:postfix-2.6.6-6.el6_7.1.x86_64 has missing requires of mysql-libs
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20190204/22d5132e/attachment.html>
More information about the Qgis-us-user
