[Qgis-us-user] Capturing two records in a shape file
Rob Bacigalupi rob at missionnorthmi.com
Mon Oct 5 07:58:54 PDT 2020
Hi QGIS User Group:
I am fairly new to QGIS and have what hopefully is a basic question.  I’m using a zip code shape file from the US census for the entire US and would like to create a new layer with just two zip codes.  When I go into properties/control feature symbology/add rule-based layer then go to create the filter, that’s where I run into trouble.  I’ve tried creating an expression string as follows:
“ZTCA5CE10 = “zip code 1” OR “zip code 2”
but it only returns the first zip code.
Any suggestions?
Thanks,
Rob
More information about the Qgis-us-user mailing list
