[Qgis-us-user] plot points at known distances
Keith Jenkins
kgj2 at cornell.edu
Thu Feb 10 08:38:55 PST 2022
Hi, Len.
I think you may want to try using the Advanced Digitizing panel, which
as you digitize points will show distances from the previous point.
You can also use it to make exact angles, etc.
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#the-advanced-digitizing-panel
But if you just want a grid with regular spacing, you could use the
"Create Grid" tool and then clip the result to your polygon.
Cheers,
Keith
On Thu, Feb 10, 2022 at 9:25 AM Len Meier <lxmeier.meier at gmail.com> wrote:
>> Hello Community. I am trying to produce a grid within a polygon. I have measured the distances between points along the x and y axes. GPS coordinates are not precise enough so I want to plot points specified distances along the x and y axes. However when I go to create the points, the measure tool turns off. I have not found a way to show the distance as I go from one point to the next.
>> Alternatively, If there was a tool that utilizes a table containing the distances for plotting along a line, I could digitize lines along the poly boundaries and do it that way, I was an ArcGIS user for years until movint into management, and then retiring. So I am just learning QGIS.
More information about the Qgis-us-user
