[Qgis-us-user] Trouble fully installing QGIS on Mac
    Farr, Thomas
    tom_farr at alumni.caltech.edu
    Tue Oct 11 15:00:49 PDT 2022
Hello,
I’m no expert in Unix or Mac, but have been trying to install QGIS in order to process ASTER satellite images. The install of 3.22 LTR seems to go fine, though some error messages do show up, the one in red and yellow says:
2022-10-10T16:42:52     WARNING    GRASS init error : Problem in GRASS initialization, GRASS provider and plugin will not work : Module built against version 2021-02-10T17:13:06+00:00 but trying to use version 2021-02-10T17:08:53+00:00. You need to rebuild GRASS GIS or untangle multiple installations.
And when I try to use Grass to work on the images, the input option is greyed out. If I go to Grass options, I get a message that it can’t find Grass.
I’ve poked around to see if I have multiple Grasses installed to no avail. I tried installing 3.16 LTR, but no change. I found a file called default.qgc that Grass seemed to want and gave the path in the Grass options dialog, but no change. That about exhausts my ability to trouble-shoot. Does anyone have any suggestions?
Thanks in advance.
MacBook Pro, OS 12.6, Monterey. QGIS 3.22 LTR
_______
Tom Farr
tom_farr at alumni.caltech.edu<mailto:tom_farr at alumni.caltech.edu>
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20221011/d964d797/attachment.htm>
More information about the Qgis-us-user
