[Qgis-user] Text import does not work in 0.9.2x1
John C. Tull
john.tull at wildnevada.org
Fri Apr 4 19:46:26 PDT 2008
Goyo,
It worked for me with svn build (8319), although I am having problems
with projection settings for layers now...
John
On Apr 4, 2008, at 2:48 PM, Goyo wrote:
> Hi All
> I have just updated to 0.9.2x1 from Ubuntu Gutsy repository (32
> bits) an
> cannot make the text import plugin work. I always get a message "The
> layer is not a valid layer and cannot be added to the map".
> The layers were successfully imported in previous 0.9 versions and
> even
> the simplest files fail now, like
> x y
> 1 1
> I just wanted to test if there are people experimenting the same
> regression or I missed something before filing a bug report.
> Best regards,
> Goyo
> Qgis-user mailing list
