[Qgis-user] compiling on Gentoo (ebuild)
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Wed Apr 9 05:52:30 PDT 2008
Hello all.
I'm new to the list (although not new to QGIS).
I tried to compile QGIS 0.91 in Gentoo Linux using the info on this page:
http://qgis.org/content/view/100/99/
but it failed...
here are my error msgs:
eclipse guano # emerge -vb qgis
These are the packages that would be merged, in order:
Calculating dependencies... done!
[ebuild N ] sci-geosciences/qgis-0.9.1-r1 USE="grass gsl python
-debug -gps -postgres
-samples" 0 kB [1]
Total: 1 package (1 new), Size of downloads: 0 kB
Portage tree and overlays:
[0] /usr/portage
[1] /usr/local/portage
>>> Verifying ebuild Manifests...
>>> Emerging (1 of 1) sci-geosciences/qgis-0.9.1-r1 to /
* qgis_0.9.1.tar.gz RMD160 SHA1 SHA256 size ;-) ...
[ ok ]
* checking ebuild checksums ;-) ...
[ ok ]
* checking auxfile checksums ;-) ...
[ ok ]
* checking miscfile checksums ;-) ...
[ ok ]
* checking qgis_0.9.1.tar.gz ;-) ...
[ ok ]
>>> Unpacking source...
>>> Unpacking qgis_0.9.1.tar.gz to
/var/tmp/portage/sci-geosciences/qgis-0.9.1-r1/work
* Applying qgis-0.9.1-cmake.patch ...
* Failed Patch: qgis-0.9.1-cmake.patch !
* ( /usr/local/portage/sci-geosciences/qgis/files/qgis-0.9.1-cmake.patch )
* Include in your bugreport the contents of:
* /var/tmp/portage/sci-geosciences/qgis-0.9.1-r1/temp/qgis-0.9.1-cmake.patch-22271.out
* ERROR: sci-geosciences/qgis-0.9.1-r1 failed.
* Call stack:
* ebuild.sh, line 49: Called src_unpack
* environment, line 3076: Called epatch 'src_unpack'
* environment, line 1822: Called die
* The specific snippet of code:
* die "Failed Patch: ${patchname}!";
* The die message:
* Failed Patch: qgis-0.9.1-cmake.patch!
* If you need support, post the topmost build error, and the call
stack if relevant.
* A complete build log is located at
'/var/tmp/portage/sci-geosciences/qgis-0.9.1-r1/temp
/build.log'.
* The ebuild environment file is located at
r1/temp/environment'.
* This ebuild is from an overlay: '/usr/local/portage/'
any help is greatly appreciated
Carlos
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
