SV: [Qgis-user] How to get xyz points into a Qgis map?
Jan Valenta valenta at irsm.cas.cz
Tue Apr 22 06:17:01 PDT 2008
Have you set the "delimiter field" for the column delimiter you are
using?
Jan.
Rosenkranz, Brigitte Christine píše v Út 22. 04. 2008 v 15:09 +0200:
> Hi Jan,
> Thanks for your answer. I tried the delimited text plugin already and I was running in the problem that I never can press the parse button. It seems like it does not accept my ASCII file. I can not chose the X and Y field neither. Do you have any idea what could be wrong there?
> Thanks again and best regards,
> Gitte
> -----Oprindelig meddelelse-----
> Fra: Jan Valenta [mailto:valenta at irsm.cas.cz]
> Sendt: 22. april 2008 14:58
> Til: Rosenkranz, Brigitte Christine
> Emne: Re: [Qgis-user] How to get xyz points into a Qgis map?
> Try the "delimited text" plugin. It is designed to import ASCII files
> with column data.
> Jan.
> Rosenkranz, Brigitte Christine píše v Po 21. 04. 2008 v 14:23 +0200:
> > Dear all,
> > I am working with elevation data which we have in raster format.
> > I started short time ago to work with Qgis and I try to get my quality
> > reference points which are points with XY and Z coordinates into my
> > Qgis map. Unfortunately until now without success. Does anybody know
> > how I can visualise these kind of data in Qgis? I can't find anything
> > about it in the user guide.
> > The datafile is normally just a text file with X Y Z coordinates.
> > Thanks for helping d:o)
> > And best regards from sunny Copenhagen,
> > /Gitte
> > Brigitte Rosenkranz
> > Kort & Matrikelstyrelsen
> > National Survey and Cadastre
> > Rentemestervej 8
> > DK-2400 København NV
> > Dir. tlf. +45 72 54 5203
> > e-mail: bicro at kms.dk
> > Tlf. (+45) 72 54 50 00
> > Fax. (+45) 72 54 50 51
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
