[Qgis-user] GRASS plugin
John C. Tull
john.tull at wildnevada.org
Tue Apr 22 14:19:53 PDT 2008
Albert,
I believe you can find all the information you need on this web page:
http://www.kyngchaos.com/wiki/software:qgis
The link to qgis binaries is provided for either Tiger (10.4) or
Leopard (10.5), and the additional requirements are noted just below
those links. You will find each of those required frameworks here:
http://www.kyngchaos.com/wiki/software:frameworks
I hope that helps,
John
On Apr 21, 2008, at 6:34 AM, Albert Arcand wrote:
> John,
> Could you please list the name of the file I should down load. I do
> not know what the function of a binaries. So I do not know what to
> look for as in the name of the software. Also I am confuse in how
> X-11, Leopard , and, Grass and Qgis work together. A diagram would
> be helpful. Any way I do want to thank you for your help in the past.
> -Albert
> Learning one byte at a time, ok maybe just a bit at a time.
> On Friday, April 18, 2008, at 06:02PM, "John C. Tull" <john.tull at wildnevada.org
> > wrote:
>> Did you install binaries from http://www.kyngchaos.com ? I am
>> thinking
>> you did not, as you should be able to grab qgis-0.9.2rc1 from that
>> website, along with all the necessary frameworks and grass binaries.
>> Cheers,
>> John
>> On Apr 18, 2008, at 3:38 AM, Albert Arcand wrote:
>>> Having install the following program on my Mac with MacOs 10.51:
>>> Qgis 9.0; GRASS; X-11. The problem I am having, unable to link the
>>> program together. When I start Qgis it does not find GRASS. When
>>> starting GRASS it does not find X-11. All these programs are install
>>> in my Application folder.
>>> Sincerely,
>>> Albert A. Arcand Jr.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
