[Qgis-user] grass layer editing - Solved
Tim Sutton
tim at linfiniti.com
Tue Aug 5 13:59:57 PDT 2008
Hi Edmondo
Right you encountered a bug which I recently fixed - QGIS will now (in
next release) try to fall back on the default theme if it finds icons
are missing. Glad you got it worked out!
Regards
Tim
2008/8/5 Edmondo <edmondo.elisei at gmail.com>:
> Hi,
> It works fine now.
> I installed QGis 0.11 on windows.
> I'm using the "nkids" skin, and I seen folder "themes/nkids/grass" there
> isn't.
> I needed copying the folder "grass" from "themes/default" to themes/nkids.
> Thanks
> best regards
> Edmondo
> Tim Sutton wrote:
>> Hi Edmondo
>> You will need to provide a more info before anyone could help you -
>> what OS are you using, what distro, how did you install etc. Provide
>> more info and others may be able to help you....
>> Regards
>> Tim
>> 2008/7/29 Edmondo <edmondo.elisei at gmail.com>:
>>> Hi All,
>>> my editing panel "GRASS Edit" doesn't show the icons on toolbar.
>>> It happens with all last releases (0.9.1 - 0.10 - 0.11)
>>> Thanks
>>> View this message in context:
>>> http://www.nabble.com/grass-layer-editing-tp18714370p18714370.html
>>> Sent from the qgis-user mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton
>> QGIS Project Steering Committee Member - Release Manager
>> Visit http://qgis.org for a great open source GIS
>> Blog: http://tim.linfiniti.com
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> View this message in context: http://www.nabble.com/grass-layer-editing-tp18714370p18826456.html
Tim Sutton
Skype: timlinux
