[Qgis-user] Write Coordinates to Attribute Table
    Carson Farmer
    carson.farmer at gmail.com
    Mon Aug 25 01:35:57 PDT 2008
Darren,
> I'm looking for a way to write X/Y coordinates for a point shapefile
> back into two columns (X/Y) in the shapefile's attribute table.  Can
> QGIS do this?  If so, how?
You can try the compute geometry plugin that comes with fTools.  This
will take your input shapefile, compute the x and y coordinates, and
then create an identical new shapefile with the added fields.  You can
also download and install the individual compute geometry tool.
Both are available here:
http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml/
Just add this to your plugin installer repository list.
> Ideally, the less steps required the
> better, as this is something that will need to be repeated multiple
> times--thus a script would be ideal!
I'll see if I can adapt a simple script from the above plugin, and try
to get back to you...
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
