[Qgis-user] plugin for home range calculations
Maciej Sieczka tutey at o2.pl
Mon Aug 25 06:03:05 PDT 2008
Paolo Cavallini pisze:
> Hi all.
> As many of you know, Anne has completed her plugin:
> http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
> You can now install it with the installer plugin, using the Faunalia
> repo http://www.faunalia.it/qgis/
> adding http://faunalia.it/qgis/plugins.xml to your sources list.
Hi Paolo, Anne,
Plugin's description is wrong in the "Plugin Installer". Also the name
is not telling too much *to me*: "pluginProva".
If no input layer is selected pressing OK yields an error:
An error has occured while executing Python code:
   File "/home/shoofi/.qgis//python/plugins/pluginProva/plugin.py", line
174, in run
     Dialog.opt = self.collectedOptions()
233, in collectedOptions
     opt["io"]["layer"] = "%s" %
self.cmb_in_lyr_list[self.cmb_in_lyr.currentIndex()]
IndexError: list index out of range
Python version:
2.5.2 (r252:60911, Aug 14 2008, 13:49:08)
[GCC 4.3.1]
Python path:['/usr/local/qgis/share/qgis/python',
'/home/shoofi/.qgis//python/plugins',
'/usr/local/qgis/share/qgis/python/plugins', '/usr/lib/python25.zip',
'/usr/lib/python2.5', '/usr/lib/python2.5/plat-linux2',
'/usr/lib/python2.5/lib-tk', '/usr/lib/python2.5/lib-dynload',
'/usr/local/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages/Numeric',
'/usr/lib/python2.5/site-packages/PIL',
'/usr/lib/python2.5/site-packages/gst-0.10',
'/var/lib/python-support/python2.5',
'/var/lib/python-support/python2.5/gtk-2.0',
'/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode',
'/home/shoofi/.qgis/python/plugins/fTools/tools']
Debian testing amd64.
Maciek
Maciej Sieczka
www.sieczka.org
