[Qgis-user] plugin for home range calculations
John C. Tull john.tull at wildnevada.org
Mon Aug 25 08:16:12 PDT 2008
On Aug 25, 2008, at 5:39 AM, Paolo Cavallini wrote:
> Hi all.
> As many of you know, Anne has completed her plugin:
> http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
> You can now install it with the installer plugin, using the Faunalia
> repo http://www.faunalia.it/qgis/
> adding http://faunalia.it/qgis/plugins.xml to your sources list.
> Be careful of the dependencies (R-related). I have tested on a fresh
> install, and it works smoothly. I hope this will make it esier for
> others to test.
> Great job Anne!
> All the best.
I look forward to trying this out. Can I make the recommendation that
the dependencies be added to the plugin description in the repository?
Thanks,
John
