[Qgis-user] World file
David Fawcett
david.fawcett at gmail.com
Fri Dec 19 11:34:38 PST 2008
Augustin,
Below is a Python function that I threw together to calculate world
file params for a rotated image and write them out to a file. It
might be of some help to you.
David.
# creates a world file for the air photo
# Args:
# outputFile - directory to write the world files to
# xResolution - pixel resolution in x direction
# yResolution - pixel resolution in y direction
# angleDeg - the angle of rotation in degrees
def writeWorldFile(outputFile,xResolution,yResolution,angleDeg,rotatedUlXcoord,rotatedUlYcoord):
angleRad = -math.radians(angleDeg)
line1 = xResolution * math.cos(angleRad)
line2 = -xResolution * math.sin(angleRad)
line3 = -yResolution * math.sin(angleRad)
line4 = -yResolution * math.cos(angleRad)
line5 = rotatedUlXcoord
line6 = rotatedUlYcoord
try:
newWorldfFile = open(outputFile+".jgw","w")
except:
print "couldn't open file"
fileText = str(line1) + '\n' + str(line2) + '\n' + str(line3)
+ '\n' + str(line4) + '\n' + str(line5) + '\n' + str(line6) + '\n'
newWorldfFile.write(fileText)
newWorldfFile.close()
return
On Fri, Dec 19, 2008 at 10:31 AM, José María Michia
<jose.maria.michia at gmail.com> wrote:
> 2008/12/19 Agustin Lobo <aloboaleu at gmail.com>:
>> This could be considered a bit off-topic.
>> If a jpg image were well alligned with a N-S grid,
>> the world file would be something like:
>> 0.4007552
>> 0
>> 0
>> -0.4007552
>> 438209.4
>> 4625526
>> but if I have to rotate 90 deg. to the left, how should I make the
>> file?
>> Any orientation,pointer etc?
> The file TFW must be:
> 0
> 0.4007552
> 0.4007552
> 0
> 438209.4
> 4625526
> For explanations see:
> http://www.omg.unb.ca/~jonnyb/processing/geotiff_tifw_format.html
> http://lists.maptools.org/pipermail/geotiff/2007-January/000362.html
> Saludos
> José María
>> Thanks
>> Agus
>> Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> LLuis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> email: Agustin.Lobo at ija.csic.es
>> http://www.ija.csic.es/gt/obster
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
