[Qgis-user] dependencies on OpenSuSE 11.1 KDE4
Otto Dassau otto.dassau at gmx.de
Tue Dec 30 01:37:59 PST 2008
Dear Gian,
On Mon, 29 Dec 2008 20:36:39 -0300
"G. Paolo Sanino V." <research at leviathanchile.org> wrote:
> Hi,
> I just moved to the new openSUSE 11.1 (x86_64) with KDE 4.1.3.
> Not that happy with the changes but too late to walk back...
> Under OS11.0 is was as simple as use Yast, search for Qgis and thet getting
> installed. However, in 11.1 qgis does not shows up on the defaults list of
> application packages. Then after adding several repositories it shows up at
> "factory". As well as from www.opensuse.org, the one clik utility worked fine
> in finding qgis under OpenSuSE-Factory. However, using the online tool or Yast
> with the repositories, I cannot get QGIS installed due to the missing:
> libgeos-3.0.0.so()(64bit).
> Looking at RPM find and other sites, I found two packages that contain this
> library but no way to install any of them, as they present even more failed
> dependencies during the attempts.
> Is this happening to somebody else? if so, have you found a workaround to get
> qgis installed in this distro?
> Thanks a lot! and congratulations for the great work on QGIS.
I just started to create QGIS 1.0.0 packages for OpenSUSE at the OpenSUSE
Application:Geo server. Don't know if that is where you have been looking for
QGIS?
http://download.opensuse.org/repositories/Application:/Geo/
Most versions are done, but there are some dependencies failing for 11.1 and
factory yet. I will have a look to fix this soon, before we have the official
QGIS release.
regards,
 Otto
> Gian
