[Qgis-user] Configuration file in Windows
Goyo
goyodiaz at gmail.com
Fri Feb 15 11:16:08 PST 2008
Thank you, Gary. Yes I should be able to do that but actually I didn't.
Selecting that toolbar had no effect.
I didn't even think about the registry since the editor is disabled by
the system administrators and I've not used it for years. It's a complex
process to get that privileges granted in that corporate environment so
I did some googling and learned that I could use reg in the command
line. I deleted the /hkcu/software/quantumgis key and solved my problem.
I saved a copy of the deleted key, in case it's of interest for someone.
Goyo
El jue, 14-02-2008 a las 16:13 -0900, Gary Sherman escribió:
> On Feb 14, 2008, at 11:21 AM, Goyo wrote:
> > Hello everyone,
> > I'm using QGIS 0.9.1 in Windows XP, installed from the installer
> > provided in the downloads page. I've lost the attribute data toolbar,
> > it's not shown even if I select it in the toolbar menu. I guess
> > something is broken in the configuration file. I've seen that it's
> > ~/.config/QuantumGIS/qgis.conf and that removing it QGIS return to
> > default configuration, but I can't find any qgis.conf in Windows.
> > I uninstalled QGIS and the installation directory was completely
> > removed. Then I searched my user folder for qgis related files --even
> > hidden ones and removed qgis.db, the only one I was able to find. But
> > still QGIS remember the old broken configuration when I install it
> > again.
> > I'm hoping someone can tell me how to reset configuration to
> > defaults in
> > Windows and get all my toolbars back.
> > Thanks in advance
> > Goyo
> On Windows the QGIS settings are stored in the registry. You should be
> able to get the toolbars back by right-clicking in the toolbar area
> and selecting the ones you want visible.
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> -Micro Resources: http://mrcc.com
> *Geospatial Hosting
> *Web Site Hosting
> -Desktop GIS Book:
> *http://desktopgisbook.com
> "We work virtually everywhere"
