[Qgis-user] Mapserver Export
Micha Silver micha at arava.co.il
Tue Feb 19 02:45:38 PST 2008
Pardon for hi-jacking the thread, but may I point out two other problems
I find with the mapserver export that might be easy to fix?
The layers in a qgis project are exported to the *.map file in the same
order that they appear in the qgis table of contents. In qgis (like most
desktop gis apps) the top layer in the TOC also appears "on top" of the
other layers. But in mapserver it's reversed: the layers are pushed into
the graphics file in the order they appear in the *.map file, so the
bottom most layer displays "on top" of all the others.  Would it be
possible to write the layers into the *map file in reverse?
In addition, I noticed that PostGIS layers from qgis are always (?)
entered into the map file with a FILTER line in the LAYER section. If
there is no filtering done on the PostGIS layer then the FILTER line is
entered with an empty string, i.e.
LAYER
    FILTER ''
END
This causes mapserver to make an empty WHERE clause in it's PostGIS
query which then throws an error. Wouldn't  it be better to push the
FILTER line into the *.map file *only* when the layer in qgis  actually
is queried / filtered?
Many thanks,
Micha
Micha Silver
Arava Development Co
+972-8-6592270
