[Qgis-user] Island polygon
Ralf Suhr
Ralf.Suhr at bauing.uni-weimar.de
Wed Jul 2 02:53:32 PDT 2008
Hi Intengu Technologies,
you have to build the geomunion of the six inner polygons. Take the inner
geomunion and substrakt this from the outer polygon. This will produce a
hole, what the main problem of the dataset is.
I think the shapefile was build with simple polygons. You need a dataset with
multipolygons.
Regards
Ralf
Am Mittwoch 02 Juli 2008 schrieb Intengu Technologies:
> How do I clean island polygons - I have imported this shapefile (v.ogr) as
> a grass vector layer and ran the v.clean command. Instead of having 7
> records I have 13 records - the reason is that each island polygon also
> takes the records of the outer polygon. How can I solve this.
