[Qgis-user] qgis0.10_lenny
Carson Farmer
cfarmer at uvic.ca
Mon Jul 7 10:36:58 PDT 2008
It looks like you aren't able to load any python plugins...
What did you use to install QGIS?
C
>> Can somebody help me?
>> When launching QGIS some plugins (almost all) not loads
>> correctly. Here the log shell:
>> Loaded /usr/lib/qgis/libcopyrightlabelplugin.so
>> Loaded /usr/lib/qgis/libdelimitedtextplugin.so
>> Loaded /usr/lib/qgis/libdelimitedtextprovider.so
>> Loaded /usr/lib/qgis/libgeorefplugin.so
>> Loaded /usr/lib/qgis/libgpsimporterplugin.so
>> Loaded /usr/lib/qgis/libgpxprovider.so
>> Loaded /usr/lib/qgis/libgrassplugin.so
>> Loaded /usr/lib/qgis/libgrassprovider.so
>> Loaded /usr/lib/qgis/libgridmakerplugin.so
>> Loaded /usr/lib/qgis/libogrprovider.so
>> Loaded /usr/lib/qgis/libpggeoprocessingplugin.so
>> Loaded /usr/lib/qgis/libpostgresprovider.so
>> Loaded /usr/lib/qgis/libquickprintplugin.so
>> Loaded /usr/lib/qgis/libscalebarplugin.so
>> Loaded /usr/lib/qgis/libspitplugin.so
>> Loaded /usr/lib/qgis/libwfsplugin.so
>> Loaded /usr/lib/qgis/libwfsprovider.so
>> Loaded /usr/lib/qgis/libwmsprovider.so
>> <module 'mapserver_export' from
>> '/usr/share/qgis/python/plugins/mapserver_export/__init__.pyc'>
>> Error in sys.excepthook:
>> Traceback (most recent call last):
>> File "<string>", line 2, in qgis_except_hook
>> File "<string>", line 11, in qgis_except_hook_msg
>> TypeError: argument 1 of QgsMessageOutput.setTitle() has an invalid type
>> Original exception was:
>> File "<string>", line 1, in <module>
>> File
>> "/usr/share/qgis/python/plugins/mapserver_export/mapserverexport.py", line
>> 46, in initGui
>> self.iface.addToolBarIcon(self.action)
>> TypeError: argument 1 of QgisInterface.addToolBarIcon() has an invalid
>> type
>> <module 'plugin_installer' from
>> '/usr/share/qgis/python/plugins/plugin_installer/__init__.pyc'>
>> File
>> "/usr/share/qgis/python/plugins/plugin_installer/installer_plugin.py",
>> line 33, in initGui
>> type
>> <module 'arpat' from '/home/sam/.qgis//python/plugins/arpat/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/arpat/ArpatPlugin.py", line 58, in
>> initGui
>> self.toolBar = self.iface.addToolBar("ARPAT")
>> TypeError: argument 1 of QgisInterface.addToolBar() has an invalid type
>> <module 'bettertable' from
>> '/home/sam/.qgis//python/plugins/bettertable/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/bettertable/BetterTablePlugin.py",
>> line 34, in initGui
>> self.iface.addToolBarIcon(self.actionOpenTable)
>> type
>> <module 'centroids' from
>> '/home/sam/.qgis//python/plugins/centroids/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/centroids/generateCentroids.py",
>> line 60, in initGui
>> type
>> <module 'extractnodes' from
>> '/home/sam/.qgis//python/plugins/extractnodes/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/extractnodes/extractNodes.py",
>> line 56, in initGui
>> type
>> <module 'findbyattr' from
>> '/home/sam/.qgis//python/plugins/findbyattr/__init__.pyc'>
>> <module 'geoprocessing' from
>> '/home/sam/.qgis//python/plugins/geoprocessing/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/geoprocessing/__init__.py", line
>> 15, in classFactory
>> return Geoprocessing(iface)
>> File "/home/sam/.qgis//python/plugins/geoprocessing/geoprocessing.py",
>> line 31, in __init__
>> userPluginPath =
>> QFileInfo(QgsApplication.qgisUserDbFilePath()).path()+"/python/plugins/geoprocessing"
>> TypeError: argument 1 of QFileInfo() has an invalid type
>> <module 'myTest' from
>> '/home/sam/.qgis//python/plugins/myTest/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/myTest/testplugin.py", line 31, in
>> initGui
>> type
>> <module 'randompoints' from
>> '/home/sam/.qgis//python/plugins/randompoints/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/randompoints/generateRandom.py",
>> line 59, in initGui
>> type
>> <module 'srsmanagement' from
>> '/home/sam/.qgis//python/plugins/srsmanagement/__init__.pyc'>
>> File
>> "/home/sam/.qgis//python/plugins/srsmanagement/projectionManagement.py",
>> line 66, in initGui
>> type
>> <module 'tablemanager' from
>> '/home/sam/.qgis//python/plugins/tablemanager/__init__.pyc'>
>> File "/home/sam/.qgis//python/plugins/tablemanager/tableManager.py",
>> line 45, in initGui
>> type
>> Warning: Object::connect: No such signal QgsDbSourceSelect::finished()
>> Warning: Object::connect: (sender name: 'QgsDbSourceSelectBase')
>> Bye
> Hello everyone,
> someone can help me understand these errors in QGIS?
> I am not using more because of this mistake!
> Salvatore Larosa
> GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
