[Qgis-user] Ubuntu Version 0.11 has some defects
Micha Silver
micha at arava.co.il
Fri Jul 18 02:47:38 PDT 2008
Hello:
Tim Michelsen wrote:
>> Timmie is your 8.04 install fresh or an upgrade? Mine is on an
>> upgraded machine, I'll try on a fresh install later today to see if
>> that line provides any new information.
> It's a upgrade.
I can verify the same problem. I tested on two Hardy machines, both
fresh installs. Plugin Installer is no longer available, and the extra
plugins I had added before with 0.10 are also no longer available.
>>> What version of python-qt4 are you running?
> dpkg -l|grep python-qt4
> ii python-qt4 4.3.3-2ubuntu4.1
> Python bindings for Qt4
> ii python-qt4-common 4.3.3-2ubuntu4.1
> Shared files for PyQt4
Same :
micha at akev:~$ dpkg -l | grep python-qt4
ii python-qt4
4.3.3-2ubuntu4.1 Python bindings for Qt4
4.3.3-2ubuntu4.1 Shared files for PyQt4
But note that some qgis libraries from 0.10 are still lying around:
micha at akev:~$ dpkg -l | grep qgis
ii libqgis-core0.10
0.10.0-6~hardy QGIS Geographic Information System -
shared
ii libqgis-core0.11
0.11.0-1~hardy1 Quantum GIS - shared core library
ii libqgis-gui0.10
shared
ii libqgis-gui0.11
0.11.0-1~hardy1 Quantum GIS - shared gui library
ii libqgisgrass0.10
shared
ii libqgisgrass0.11
0.11.0-1~hardy1 Quantum GIS - shared grass library
ii qgis
0.11.0-1~hardy1 Geographic Information System (GIS)
ii qgis-plugin-grass
0.11.0-1~hardy1 Plugin for accessing GRASS data from
Quantum
Should I manually remove these? (Should they have been removed by the
pkg configuration?)
Thanks,
Micha
