[Qgis-user] QGIS segfaulting
pcreso at pcreso.com
Tue Jul 22 12:48:44 PDT 2008
Hmmm...
In which case it may be worth using a libgdal compiled with an earlier version of gcc for the GEO repository, at least until there is a fixed version of GDAL available?
I have found that mixing local compiles with precompiled packages in this sort of situation can be fraught with hassles, generally beyond my limited abilities in this arena to resolve :-(
I've found that either using all compiled apps, or all pre-packaged ones works, but mixing them is seldom worth the time it takes to make them work together...
Thanks for the help....
Brent
--- On Tue, 7/22/08, Maciej Sieczka <tutey at o2.pl> wrote:
> From: Maciej Sieczka <tutey at o2.pl>
> Subject: Re: [Qgis-user] QGIS segfaulting
> To: pcreso at pcreso.com
> Cc: "Otto Dassau" <otto.dassau at gmx.de>, qgis-user at lists.osgeo.org
> Date: Tuesday, July 22, 2008, 7:20 PM
> pcreso at pcreso.com pisze:
> > I have not (yet) tried to install the 32bit version.
> The debug info
> > as suggested by Maciej is below, (not the full bt
> info, but at least
> > a more informative msg regarding the cause of the
> segfault).
> > Program received signal SIGSEGV, Segmentation fault.
> [Switching to
> > Thread 0x7f33cda8b720 (LWP 15049)] 0x00007f33cab306d0
> in sincos ()
> > from /usr/lib64/libgdal.so.1
> Fun fun fun - same thing was just noticed in GRASS - see
> [1]. I'm
> telling GDAL guys.
> [1]http://www.nabble.com/forum/ViewPost.jtp?post=18555960&framed=y
> Maciek
> Maciej Sieczka
> www.sieczka.org
